1 - 20 of 22 Posts
Just letting you guys know...
I had a clunking sound in my rear suspension, which sounded like it came from the rear right. I took it to my local Honda repair shop, and they fixed it. I was guessing it was an issue with the bushing on the shock (and even bought a bushing just in case)... but the shop fixed it by simply putting a washer there.
Apparently there was play in the rear left suspension, causing it to clunk at lower speeds. With just a washer, the clunk sound is completely gone. Cost me $102.50 to fix, ($100 labor and I'm guessing $2.50 for washer, lol)
lol interesting ... i have the same clunking noise from my rear suspension as well ... where exactly did they install the washer? above the bump stop where the nut screws down too or below it?
might give this a try if i can figure out where they put the new washer
R18 or Si?
My suspensions been doing the same thing, being clunky but it could be totally irrelevant as i have a R18 and you may have a civic.
Discussion Starter · #5 · (Edited)
Civic Si, using the Mugen Sports suspension. I installed it myself with a friend, and I'm pretty sure we didn't leave any parts out. Considering the Mugen SS is just the OEM Showas revalved, don't think it was the suspension itself. There was no clunk sound for 30k miles, and it started squeaking maybe 10k miles ago. That squeak turned into a full-on clunk maybe 2000 miles ago.
Have no idea where they put the washer =( As for being a lot of money, yeah the repair shop in general is on the pricey side, but they're good at what they do and are very friendly. $100 is the default they charge for a diagnostic. Says they used a 10mm washer.
if you possibly get a chance can u check and see if they put the washer on top where the nut screws down into? doesnt have to be right now but if you get a chance
edit: or it could be on the lower bushing where the shock connects to the hub assembly
Discussion Starter · #9 ·
Don't I have to roll back the carpet or something? D: I'll take a pic when I can. I think the washer was added toward the top, near the perch.
bushings wear out, mine wore out quicker after all my track days/canyon runs. I replaced mine and now its good as new.
Discussion Starter · #14 ·
Yeah I figured it was bushings, which is why I bought a new one and brought it to the dealer. They didn't even use it...
stance coilovers does not clunk btw.
oh, i dont blame the coils at all. i had the same issue when i had the ksports.
sweet. looks like i'll be heading to the dealer.
or can i get the bushing somewhere else?
Also hearing noises that sounds like "crrg" at the rear when rolling on road imperfections at certain speeds. Would appreciate the pics so I can check mine.
Discussion Starter · #19 · (Edited)
Blegh, I was right, they installed the washer on the right side, even though the service person said left. I knew the clunk was from the right. Huck, you can buy it for about $1 online, plus shipping. I can send it to you if you pay like the $1 for shipping, lol. Doesn't make much difference cost-wise though.
http://www.hondapartsunlimited.com/...tionID=13899&illustration=REAR SHOCK ABSORBER
Here are the pics:
Left side, no washer
Right side, washer
nice! thx aki for the pics ... i'm gunna give this a try in a lil bit n see if it helps me out as well
EDIT: just went out and installed some washers on both sides ... the clunking noise is still there but it is a lot less noticeable and annoying now lol
1 - 20 of 22 Posts
