1 - 20 of 139 Posts
Don't know if this was posted yet, but there has been a lot of steering pop threads.
Service Bulletin 09-028 Dated July 16, 2009
Clunking, Popping, or Clicking Noise From the Front While Turning
SYMPTOM
There is a clunk, pop, or click coming from the front of the vehilce when making a left or right turn at slow speeds.
PROBABLE CAUSE
The steering gearbox mounting bolts are not torqued correctly.
VEHICLES AFFECTED
2008 Civic
From VIN 2HGFA1...8H516998 thru
2HGFA1...8H599999
From VIN 2HGFG1...8H546508 thru
2HGFG1...8H599999
From VIN 2HGFA5...8H705832 thru
2HGFA5...8H799999
From VIN 2HGFG2...8H704505 thru
2HGFG2...8H799999
2009 Civic
From VIN 2HGFA1...9H500000 thru
2HGFA1...9H525040
From VIN 2HGFG1...9H500000 thru
2HGFG1...9H539364
From VIN 2HGFA5...9H700000 thru
2HGFA5...9H708331
From VIN 2HGFG2...9H700000 thru
2HGFG2...9H704887
CORRECTIVE ACTION
Retorque the steering gearbox mounting bolts.
:yeahthat:
Discussion Starter #7 (Edited)
ok im guesing this is the tsb #
09-028
edited first post also.
the bolts are on the steering gearbox its connected to the rack and pinon so
i would look there first lol. much easier with a lift. My friend works at honda
so he told me about it. He said that one bolt was just spinning like it was stripped.
Good luck guys. :thumb:
:thumb:
lb honda tried to give me **** about having coilovers..gave them the clip and set an appointment to drop off my car for service and pick up a r18 loner ahahah
would this cause a pull to the left or right?
I have pull the right I can't get rid of and it's not tire pull.. .
Discussion Starter #13
nice randy!
yeah they didnt give me a loaner, it took them damn half the day
I come back and my friend just pulls the car in the shop does it in like
15min and done. haha.
i have the same problem with mine but mine is an 06 Si and it does the same exact samething could it be the same issue and my front setup is the koni yellow inserts with nuspeed spring what do you'll think it is
Discussion Starter #16
I don't know the torque ratings on the bolts.
and k-20z3 SI take your car in and give it a try
my car makes the same noise i believe as well its an 06 civic si when turning right or left at slow speeds makes a knocking or popping sound like somethings loose
Ive had this problem on my 07 since I purchased it. Have complained many times but of course cant duplicate. It sounds terrible and everyone who rides with me freaks out when they hear the loud CLUNK from the front on turns. It stops after a little driving though.
happens to me as well.
i am lowered, but it's been happening even before i was.
i wonder if they'll still do the work even though i'm out of warranty. anyone know?
1 - 20 of 139 Posts
