1 - 16 of 16 Posts
hotrod
· Registered
Discussion starter · #1 ·
When I try to start my car all i get is a Click, click ,click.....noise but it doesn't roll over. So i Just try it again and it starts. This has happened a few times in the last 2 weeks. Anyone have a similar problem?
I think I have had this same scenario, mine is not a clicking sound (more of an electric buzz), nor do I think its being caused by a short in battery or bad starter (have had those problems with older cars). At least I hope thats not the case. My situation does not happen quiet the frequency as the OP. I have had my car since oct and have approx 7200 miles on it now. I have had that happen to me twice now in that time period.
I am wondering if its something in the vehicle immobilizer with the key?? The buzzing seems to be coming from the steering column. HHMMM I was never worried about it and I am hoping it does not cause a problem in the future.
If there's a problem with the immobilizer the engine will still crank, it just won't start. The immobilizer system (at least it used to) does not affect starter motor operation.
I have heard of a few people on this site having that same problem, turning the key and getting a buzz, click, or nothing, then trying again a few times and the car comes to life. The symptoms sound similar to that of a dead battery, but then the car suddenly starts up fine. I have not heard of anyone actually getting it fixed though, because it never happens when the dealer has the car.
Discussion starter · #8 ·
The cable on the positiv eside of the battery is as tight as it will go but I can still pull it off as easy as can be? It should be tight is there something that goes over the battery post to make it tighter or what?
Sounds like you need a new battery terminal. If the battery terminal is overtightened (or taken on and off a lot) it can get bent/stretched to the point that it can no longer properly grip the battery post.
wow. I thought I was the only one on this also. My wifes SI also has the same issue. It has happened 3 times since we purchased it brand new. Its an '07 w/ approx. 25,000 miles. I'm just gonna drive this ***** till it dies.
to me it sounds like a winding in your starter motor is shorted out, or has developed a "dead spot". More and more windings will start to short out causing your car to not be able to start more often which means you will need a new starter sooner or later.
1 - 16 of 16 Posts
