:yeahthat: or use a heat gun to be safe. But then the chrome bulb is very dim though, but it looks much nicer.as long as u get the chrome bulb that flashes amber, u will be fine. just becareful with the oven. a bit too hot will cause your headlight to melt. good luck
Keep a bulb in the circuit, it's an actual load, and it doesn't get as hot as a resistor. Go figure.also LED turn signal bulbs are not a option. they make your lights HYPERFLASH! and you have to but "load resistors" that get incredibly hot. there is no way to get rid of the hyper flash. there is no flasher or relay to replace.
