1 - 20 of 33 Posts
hey everyone,
this is the first time i actually post anything in a car forum. Although i probably check 8thcivic everyday. Anyways, my dad got me a civic on my 21st bday (a royal blue EXI). we get the JDM model here and i started modifying it since day one. The first thing i did was change the rims and the tires. I sourced these gunmetal dark 17inch rims which are really rare here. (actually it's a small country, i think they're the only ones around). I wrapped them around with Toyo Proxes T1R tires which are just phenomenal. The grip is outstanding in the dry and in the rain. I also drove them once in the snow, they were suprisingly ok. After the rims and tires, came the tint. ( 30% on all side windows; front and back)..then the trunk spoiler which was custom made...I then drove the car for like a couple of months without doing anything, i got bored..so i just started installing random things here and there. I got a 8000k xenon light conversion kit, rear parking sensors. Then on my next bday, my parents got me the KENWOOD DDX6039!!! ( I HAD BEEN NAGGING FOR IT FOR SOME TIME)..this is an amazing piece of kit...it's a double din 7 inch-wide touchscreen. It plays every single thing u could think off. dvds,mp3s,dvd audio,mpg,divx,jpgs etc...its also anti-glare and u can adjust the tilt. Apart from all of this, it just looks amazing with the dashboard. it fits amazing. Then i installed a rear-view camera simply for fun. (it's cool when ur cruising around and u see some hot chics on the side of the road, u switch it on and drive by but u can still c them clearly on the screen.)
THEN I FELT THE NEED FOR MORE POWER. basically its very expensive to order parts from the states so i have to try make the best of what is available here. One trip to the local exhaust guy, and i found a HKS muffler which was fitted on a 03 civic type r. He custom fit the backbox which needed some welding BUT DAMN it sounds amazing. I don't really know wut model or system it is, but it says HKS and im sure its original. I never thought changing ur exhaust could do all that. It basically sounds the same till like 4000 rpm, then it starts getting really loud and ends with a crazy shriek at 7000. The car revved much freely but not as freely as after i installed a custom cold air intake system. (ok this took alot of work) after spending hours on online forums, i decided to custom build my own with the help of my mechanic friend. The only worry was the placement of MAF sensor and check engine light and ****. First off we decided to build a mix of short ram and cold air system. We placed the filter inside the engine bay and hooked it to a special kind of tubing that goes all the way to front of the car. we used special stainless steel tubes. I sent one of the metal pieces to a proffessional stainless steel welder which made a place to fit the MAF sensor exactly where it was fit before ( so it would give the same readings)..the guy also welded a piece to hook the breather hose to. Then it was time to get the filter. I basically went to like a million places to find the best filter. I ended up getting this SPARCO racing filter. The guy recommended it and apart from being the most expensive, it simply looks amazing in the engine bay(see the pics) i love its color. okay after like a day of hooking everything up. I finally turned the car on. Waited like 10 mins for the ECU to reset and NO CHECK ENGING LIGHT!!! then i drove outside of the garage and kicked it down and i just couldnt belive how frickin' good it sounds. oh my god! the car feels so much faster with it. I hate the ppl that say the R18 engine is **** bla bla bla ( civic si ppl..) i know the civic si is definetly a better faster car, but still the r18 has some potential believe me. Im not sure about hp gains, but i can tell u, the car is like twice as responsive as before. Throttle response is scary. The car just jumps forward. With the exhaust, it sounds mean!! I really do advise everyone to do their own CAI. check the pics and if u need any help, please ask me.
finally..just yesterday, i installed iridium spark plugs. ( i didnt honestly feel any increase in power)
okay ive been writing for some time. hope u guys like the pics
give me all ur comments
Still dropping trout
Ummm.. A serious CAI? It seems like it may have a filter within the tube instead of having it at the end of the cai.
That's the best I can come up with. I have no idea, lol.
[edit] I win!
basically, we have tons of rain in the winter, so placing the filter at the front of the car would b dangerous i guess.. i got the idea from a friend of mine who did the same CAI on his old golf gti... it works perfectly, i really dont know y ppl dnt use a system like that. The tubing is going down all the way to the small opening in the fog-light place in the front bumper..so the it's sucking air from the best place....it's taking the air up to be filtered..then to the engine.
That's a really good idea, and it actually looks really nice. The only concerns that I can think of (at the moment) would be the effects of the heat soaking through the material that you used, and if it would throw a CEL.
I honestly don't know anything about the sparco thing that you used, could you let me know if it does let heat through. Thanks.
Discussion Starter #7
alright here's a detailed discription of the custom intake:
parts used:
*2 stainless steel corners (one hooked up to the engine, one after the filter going down) - i used these because they have very good heat properties(they keep the heat out, so basically u still have cold air inside). u would want to custom weld a place for the MAF sensor to go in. (this should be done extremely precisely and professionally to avoid CEL)
*the filter... u could buy any filter, i was going for a green air filter until i saw how good this one looks...(make sure it has a cover)...this helps keep the heat out. it's made to stay cool on the inside (no heat soaking)
* a 3inch diameter flexible tube that goes down from the filter to the front of the car.
it's actually really easy to do. a hybrid between a SRI AND A CAI
it works amazing..no check engine light no nothing... i even took it to the dealership for servicing, they resetted the ECU on purpose to make sure everything is ok...and everything was fine
Would you happen to have any pics of the intake being built? I'm really fascinated by it for some reason, lol.
repped, btw.
Thanks man. :thumb:
Oh, and have a formal "welcome to the site" while you're at it. New guy brings doughnuts. :laughing:
Just earlier today I was actually thinking about an intake similar to this... just wasn't sure how you would get the filter in there but that Sparco "airbox/filter cover" is perfect. Does it have a removable filter inside the Sparco assembly?
Welcome!
the comments I posted earlier were not meant to be racist, He is lebanese I am algerian and we both speak same language, So I welcomed him in Arabic.
Thanks
Hey welcome to the site! I hope a drop is the next mod ;)
Car would look best without too much wheel gap.
I love how you custom made that CAI. Send me one! LOL
R18's ftw :D:D:D (sometimes)
1 - 20 of 33 Posts
