1 - 4 of 4 Posts
Hello
i removed the filter sensor and i installed it again, But the check engine light is not shuttin off :S:S:S what i have to do
How many times have you driven it? Try this:
Turn the car on and drive around the block twice.
Park the car and turn it off
Repeat 3 times and it should go away. My car did this when I disconnected the wire from the MAF sensor without disconnecting the negative battery terminal.
Now, if you took the actual MAF sensor out and played with it, and touched it, you might've damaged it.
A rogue CEL can be fixed with 3 driving cycles.
1 - 4 of 4 Posts
