1 - 1 of 1 Posts
hey all, trying to loosen my chain tensioner for my cams, i know that the process is you turn the crank and then when the tension ratchets up you put a pin in the tensioner. problem is that the tensioner seems to be stuck in the position you'd put the pin. i've done this before and know that it should be moving when the crank is turned. any ideas?
1 - 1 of 1 Posts
