1 - 6 of 6 Posts
So i recently put a catdelete downpipe in my car which made the CEL turn on, but i put the stock cat back on last night and reset the ecu. The CEL comes back on after a couple miles with a strong burning fuel. Anyone have any ideas what the problem is?
What is the code you are getting? If it's something about catalyst efficiency, then it's likely either your cat itself, or the down stream O2 sensor.
If it a code for being rich/lean, then it's either the primary O2 sensor (before the cat) or the car is actually rich/lean. Then again, it could be something completely different. Check all other wiring, sensors, plugs, etc. and make sure nothing got knocked loose or damaged.
1* Man
not to hijack or anything, but if your running lean and its from the primary O2 sensor, then will spacing the sensor or a defouler help?
1 - 6 of 6 Posts
