1 - 4 of 4 Posts
I have a weird issue going on.
When I drive the car like an old lady my cel light comes. I usually stay below 4k RPM. I noticed when the car spends some time above 4k RPM that the cel goes away. Does this mean that the cat is losing its efficiency at low RPMs?
Have you checked to see what the code is? And for me 4K rpm is pretty high and I only get there when I’m having to merge onto the interstate or something.
Could be a o2 sensor. Maybe the sensor reading measurements or staying above the 4k amount. Wouldn't doubt it's a o2 or mass air flow
The CEL usually comes on and stays on. Usually if it clears itself it would be after a driving cycle or two. If it goes off and on I’d suspect a wiring issue. Check the code. Cat code is P0420 and it would be very strange for it to go on and off like that.
1 - 4 of 4 Posts
