1 - 13 of 13 Posts
Is there anyway to adjust the caster on our cars? More specifically, an FA5. I dont think there is an adjustment but I figured I'd ask.
Thanks,
Frankie
Discussion Starter · #4 · (Edited)
get hardracing front speherical lca bushings made for the ep3 or dc5. They work on our cars and give close to 2 degrees of caster adjustability. Cost is a little over 300$ for them.
Cool! Thanks!
EDIT: I cant find them. I found Hardrace but they dont seem to have what you're talking about
You can adjust the caster by adjusting the position of the subframe. There is about 2 degrees of adjustability, but its definitely not going to be as precise as those bushings.
I had my alignment tech (not at a honda dealer, don't trust them for alignments) adjusted my SF for me to get rid of the problem I had with my car pulling to the right. Just find a shop in your city that specializes in alignments and you can probably get that kind of work done.
Thanks,
Frankie
What is wrong with your caster? Our cars already have quite a bit, especially compared to previous FWD Hondas. Too much can add extra wear to the power steering.
Discussion Starter · #7 · (Edited)
I work at a shop so I can take a shot at it.
I was reading about doing a "performance" alignment on my car and Tire Rack says to use the manufacturers suggested maximum negative camber, maximum positive caster, and preferred toe settings are the way to go about getting a car to handle well on the street. So I was wondering about adjusting the caster. I'm not dead set on doing it, just curious, thats all lol
I was reading about doing a "performance" alignment on my car and Tire Rack says maximum negative camber, maximum positive caster, and preferred toe settings are the way to go about getting a car to handle well on the street. So I was wondering about adjusting the caster. I'm not dead set on doing it, just curious, thats all lol
Maximum negative camber would hurt things like braking performance, on-center stability and tire wear. There's a limit to how much of anything you want if you're not willing to live with the trade-offs. I would think I'd look at what others have done as a baseline and not try to get the maximum of anything until I was sure I even needed it and/or could live with the consequences. I'd try focusing on getting more camber in front and less in the rear before I moved on to caster.
Read this (covers caster and camber):
Suspension Tuning Negative Camber - Sport Compact Car Magazine
Discussion Starter · #9 ·
I dont have time to read that article now, but I will read it later.
I left out some important info. Tire Rack says to use the manufacturers max suggested neg camber and pos caster. Like, at the limits of the "in-spec" range, not the max settings able to be used lol
I planned to play with the camber first and maybe the rear toe. I dont know if anyone else has experienced this, but I get snap understeer. Like I'll be pushing it through a corner and it feels good, then out of nowhere, the front tires break traction and it starts to understeer severely! So I kinda want to get rid of that lol
i have problems with my caster too, i am wondering if the buddy club extended ball joints would help since i'm lowered. will post my alignment printout later.
maybe stick to herraflush stuff :p
:rotfl: oh well i thought there was a kit type thing out there but wasnt sure
but i was told by an alignment guy!!! ok?! :sadface: f u!
Cool! Thanks!
Special Projects MS
This is a shop by my house and when i spoke to them about the ep3/dc5 front lca bushings they said fitment should be the same.
I dont believe the hardrace are on the site, i'm not sure, but give them a call because they do have them in stock. Last time i was at the shop they did at least.
Hope that helps.
1 - 13 of 13 Posts
