well its a si and this happen when i driving. how can it be cuttinf fuel out?Well if it's anything besides and Si you're bouncing off the fuel cut.
Why do you want to rev so high in neutral or first gear? I know the car has a fuel cut off at around that RPM range when you're in neutral, so you don't burn the clutch, but I was not aware of first gear fuel cutoff being that low - usually around the 8k range.well its a si and this happen when i driving. how can it be cuttinf fuel out?
when on the computer came up as maf been mess up. so he clean it.its not the cat..... seems like either your MAF or Throttle Body problem
*** i just realize that never thought of it.Way to go clearing the valuable information that is freeze frame data. What kind of maf code was it?
Replacing it might fix the problem but you don't know unless you trouble shoot it properly
