If you wanted to do it right you would wet sand then do a base coat. That way the paint will grab onto the base coat. If you just paint over it it will not hold as good and you will get runs in the paint.
you need to wet sand the entire surface and then use a scuff pad to even out the sanding and make sure you've covered every crany of it, if you dont the paint lift after it cures:thumb:
