1 - 20 of 21 Posts
· Registered
I own a 2006 Honda Civic 8th Gen 2.0s
I bought it 2nd hand and every time the car is cold it jerks when I shift from P to D/R
I also changed my ATF fluid last September.
Aside from that shifting/acceleration has no issues.
· Super Moderator
8th gen Civic used the CVT in the Hybrid models only. OP states a 2.0 and is from the Philippines, as far as I've read, the 5 speed automatic was used as well. OP (mikkosilos), did your car come with a manual? If not, there may be a sticker under the hood stating what fluid to use. Anyway, I highly doubt the OPs 2006 Civic has a CVT.
· Registered
My car is not a hybrid it doesnt come with CVT
· Registered
Discussion Starter · #9 ·
Did you do a drain and fill or "flush"? If drain, how many times?
When you're changing gears, are you completely stopped? Try waiting a second after stopping before changing gears.
Drain and filled once. I am stopped when I change gears because its from Park to Drive/Reverse.
Would ATF Dialysis solve the problem? I want to hear options first because it doesnt come cheap.
· Registered
Discussion Starter · #10 ·
The options other gave me is ATF dialysis, Shift solenoid and worse come to worse if transmission rebuild.
Just to let you know again that the jerk only happens during cold start from P to D/R.
No issues on shifting, accelerating, high speed.
· Registered
oops, my bad,
could be the previous owner drove too many miles with old ATF fluid. av911 is right, drain and fill multiple times. Could be wise to drive a month or 2 between each 'rinsing' operation. Takes some money for the fluid tho, but when it does eventually reduce your problem its cheaper than rebuild.
· Registered
08' Hybrid, still all stock, bought new, still running!
Had a similar issue with an 08' Hybrid. Fix was new plugs and FI's... but IIRC, the plugs were the most noticeable difference.
How many miles on your 06'? When were the plugs changed last? Iridium plugs? ...should be replaced before 100k miles expires on the current plugs, IMPO.
· Registered
Discussion Starter · #16 ·
The vehicle is currently at 88,000 KM. I don't know if its tampered or not.
· Registered
54k miles? On an 06'? Wow. Are you sure this is the original mileage?
At this point I would suggest you pull all the coil packs, (one at a time) and check for any burn marks around the base. If so, replace. here are the I have 3 that were replaced @ 193k miles. The other 8, on a Hybrid (2 plugs per cyl), looked good, no white synge marks.
1 - 20 of 21 Posts
