I am in the middle of a large repair to replace/upgrade the following:
-Oil pump chain/guides
-Crank sprocket
-Timing chain tensioner/chain/guides
-Valve lash adjust
I realized my vtc actuator also needs to be replaced. Im running the OEM cams with Skunk2 I/H/E and wide bore TB, OEM oil pump/injectors.. Camshafts are actually good, but the intake gear needs to be replaced.
Are there any other honda models’ camshafts I can use that will be compatible? Im talking salvage yard stuff, I have spent WAY too much on everything to get me here so far.
-Crank sprocket
-Valve lash adjust
