1 - 8 of 8 Posts
Hey guys.. got a quick question.. I have the buddyclub N+'s on my nhbp fg1 and im sure some of you know that the n+'s dont come with camber adjustments for the front. Now my question is does any company make any seperate camber plates for the front, where i could just take apart my front coilovers and just put on the camber plate.. the reason of why im asking this is because I bought some wheels and they are a bit too wide so im gonna camber then really negative so i dont rub.. any help would be great.. thanks.
I am making a set of camber/caster plates.. i want more caster... plus the bolts at -1.50 and above give alot of bumpsteer... I also want to make a shim for the tie rods to bring them up a little bit to help reduce the bump steer.... but the caster camber plates are by far the best set up.. but I am not to fond of the K-Mac stuff... The idea its spot on..
When you get your plates made, would you mind sharing the design? ... the design idea's would speed up local fabrication at my end, should I go that route. I may order some OE topmounts to play with anyways
Hmmm ... Why are you not fond of the K-MAC stuff ...any particular reason? ... What I have "seen" so far is pretty cool ... and these one comes in two versions Urethane and Spherical bearing bushed ...both user replacable.
Moose
1 - 8 of 8 Posts
