1 - 6 of 6 Posts
I noticed on the cobb stage 2 map for AEM v1 that the cam angle degrees only go to 45 at vtec. Isn't it possible to change everythign so that the max angle is 50? i have a tsx exhaust cam so its barely more aggressive than stock.
No, when you allow more air into the engine you will need more fuel to compensate. Just change the angles and datalog how it changed your airflow and then add fuel where needed.
1 - 6 of 6 Posts
