1 - 17 of 17 Posts
ok well to startoff i have an ex coupe with hfp suspension and hfp wheels and an automatic. but for some reason the first mile or to is a rough ride. its real bumpy, but after a mile or so it gets smoother. its real bad in cold weather. can any one of you lend a hand in my perdicament? thanks
Probably has to do with the suspension components being cold. The shock fluid and gas isn't warm yet, and the springs are still nice and comfortable from sitting all night too.
It could also be your tires. They might be prone to flat spotting after sitting.
I'm just grabbing at straws here? I know I've had tires that flat spotted before, and it feels like your tires are out of balance for a few minutes after you start driving, especially if it's cold out.
Sorry, not much help
it makes since. i had no idea what the problem could be. i just thought it was weird that it was bumpy just for a little bit and then got better. i guess there isnt a fix to this...anyone else have this problem?
Hidy Ho Neighbor
What tire size are you running? I have 215/40 18" tires they do the same thing. I think all tires get a temporary flat spot sitting overnight. Once they roll for a while, the flat spot disappears. It probably takes longer when it's cold. The feeling is more pronounced on lower profile tires.
I have this problem on an lx sedan with Si wheels/tires (stock suspension except Si rear sway bar)...When the tires have set all night, they temporarily flatspot. Once they are driven for about 2-3 minutes, they are fine...and it seems that the colder the temp gets, the longer it takes for the tires to warm-up to remove the flat spots...
Embrace the harshness...lol
I'm sure that the seals within the struts just need to warm up a bit before they soften up. It doesn't get cold enough here in New Orleans for me to experience those issues however.
1 - 17 of 17 Posts
