1 - 20 of 252 Posts
JDM Honda Parts, Golden Eagle, K-Tuned, Innovative Mounts, Megan Racing, K20 Swap Parts
YOU HAVE JUST FOUND THE BEST DEAL ON BUDDY CLUB N+ COILOVERS
100% AUTHORIZED DEALER..FULL WARRANTY
WE DO NOT DROP SHIP, WE SHIP DIRECT!!
RoBear Racing. BUDDY CLUB N+ COILOVERS: CIVIC SI 06-2010
100% AUTHORIZED DIRECT DEALER!! ORDER ONLINE ANYTIME
We have kits with NO UPPER MOUNTS
Click Here: RoBear Racing. BUDDY CLUB N+ COILOVERS: CIVIC SI 06-2010
IF YOU SEE A BETTER LEGITIMENT PRICE, LET ME KNOW, I WILL BEAT IT
N+ SPEC DAMPER" from Buddy Club is the choice complete suspension setup with resemblance of our RACING SPEC damper's excellent attributes. It is cost effective and is well rounded for the budget minded weekend club racer. With optional urethane isolated aluminum upper mount design, engineered spring rates, 15 level damper adjustability, and ride height adjustment capabilities, the N+ SPEC DAMPER can accommodate any driver's preferences.
With over 15 years of competitive racing experience, you can trust that your car will perform the way you want it to with quality components from Buddy Club.
Vehicle ride height is adjusted independently of spring pre-load. With other alternatives available on the market today, vehicle ride height is adjusted by reducing or increasing the preload on the coil spring. This primitive methold leads to inconsistent spring rates that are dependent upon the vehicle ride height. With any of the Buddy Club suspension components, including the N+ SPEC, vehicle ride height is independent of spring pre-load. This method ensures that the spring rate is always consistent, no matter how high or low your car is. In addition, it ensures that the spring is always properly positioned onto the strut and effectively reduces miscellaneous and unnessary noise.
15 Level Adjustment
Suspension adjustability is a key element when selecting a top quality coil-over system. The N+ SPEC DAMPERS are designed to accommodate a wide range of driving conditions from regular roads to prepared racing surfaces. Dampening settings ranges from hard (+4kg/mm) to soft (-4kg/mm).
Also avaialble is the optional urethane isolated upper pillow-ball mount. The urethane isolating ring keeps suspension noise to a minimal while maintaining the precision feel of a solid mounted strut.
The shock-body is constructed out of cadmium plated steel and is finished with beautifully anodized precision CNC machined aluminum ends. Urethane bushings are used when applicable to ensure a top quality product.
In a complete suspension setup, the coil-spring is a very key element. The coil-springs used on all Buddy Club suspension setups are specially made to exacting specifications by Buddy Club engineers. Each coil spring is manufactured to exacting tolerances to ensure performance in every demanding situation.
To ensure that the N+ SPEC Dampers stay looking superb through your years and years of ownership, each precision CNC machined aluminum component is beautifully burgandy anodized and each steel component is cadmium plated for corrosion resistance. Great attention to detail was taken to ensure that you will be completely satisfied with your ownership of Buddy Club components.
This bearing seat is developed based on data acquired from various competitions and racing experience. It is a brand new design in order to prevent the vibration noise of the spring on the Macpherson systems. It will increase the overall performance of the suspension by decreasing the twisting tension between the spring and the damper
PM price please.
Also what is the difference between getting the mount and not, do I need it?
1 - 20 of 252 Posts
