Do you have the factory service manual? If not, I recommend using this one: https://cardiagn.com/2006-2009-honda-civic-gx-service-manual-pdf/
Thanks for the link FD7683, I do have the factory service manual, but couldn't find any info regarding the gapping spec between the brake master cylinder push rod and the brake booster push rod. I assume it is factory set from the part manufacturer? Just wanted to verify that the spec is indeed correct for the OEM parts that I have installed.Do you have the factory service manual? If not, I recommend using this one: 2006-2011 Honda Civic Service Repair Manual and Wiring Diagram | PDFs Free Online
