1 - 6 of 6 Posts
your hands will slip with a dremel. get a carbide bit in the size you need, measure measure measure measure measure, then put a mark when you need the hole drilled, then measure measure, walk away take a glance, then remeasure. use a tappet to put a mini dimple in the fender, walk away triple check your location. measure and drill
in short. you a carbide bit and a drill :thumb:
1 - 6 of 6 Posts
