Car is an 06 EX coupe, NHBP, with light tan interior. Nothing very original here - just following what others have done. Special thanks to:
XTV-Sidecar
PeliROJO
Kicker Jace
Tiznonay
Jgams
& many others for the DIYs and/or pics. I'd have never thought to do this stuff if I hadn't seen it here.
I used 9-LED festoons for the dome & both map lights and the Electropods motorcycle kit many others have used. I hard-wired the Electropod setup - no switch - for a cleaner install. Tapped into the light blue & pink wires described in the DIYs, so they come on & fade out with the interior lights. However, turning on the dome or map lights does not make the electropods light up. Works exactly the way I wanted. The Electropods kit came with 6 "pods" and 2 bars. The bars are strips of 6 LEDS in a row & the pods are wired together as pairs of 2 pods. I used one set of pods (2 pods that are wired to each other) for each front footwell and one bar under the rear of each front seat. I had one set of pods left over.
For the license plate lights, I used white LEDs. 2 different ones - wanted to compare & choose best one, but will probably leave mismatched pair in place.
Part sources & price list:
Total $73.03
Pics below. The blue lights are VERY bright. Almost too much. The hotspots you see in the pics aren't there in real life. Camera insisted on such a slow shutter & I didn't feel like messing with it all night. The light glows pretty evenly and doesn't have those harsh concentrations like in my pics.
The license plate lights are one of each part number listed above. Not much difference between them, so you could save $1.20 & go with the 6-LED bulb vs the "high power" LED. In my pics, the 6-LED bulb is on the left & the 1-LED is on the right. The specs are WLED-W6 - 9,300 mcd (brightness) & 9600°K (color), WLED-WHP 54,000 mcd & 4500°K. The bulb on the right illuminates the plate a little more, but either one is significantly whiter and brighter than stock.
XTV-Sidecar
PeliROJO
Kicker Jace
Tiznonay
Jgams
9-LED blue festoon bulb
Superbright LEDs part# 3022-B9
$3.45 (times 3)
1-LED white 194/168 wedge
Superbright LEDs part# WLED-WHP
$4.95
6-LED cool white 194/168 wedge
Superbright LEDs part# WLED-W6
$3.74
StreetFX Electropods blue oval motorcycle kit
From eBay seller americanclassicmotors
$48.99 shipped
Superbright LEDs shipping fee
$5
Total $73.03
