1 - 20 of 46 Posts
So i got my blazer fogs in today and within a couple weeks i plan to retro them into some k2motor plastic fog lights.
i have some already on my car hid with lexan, im buying new lights to start fresh from so i dont have to remove my bumper until its done.
anyway, if you have tips or suggestions, throw the my way.
id love to hear how different people have done their lights.
thanks.
ill have some pictures maybe saturday
take ur time and make sure u dont cut off the adjustment mount... u might have to take off ur bumper and mount ur retro to make sure ur cutoff is straight..
I used fibreglass mat and J-B Weld to hold mine together, has worked out well so far.
But I had to cut off the adjustment bit so now to aim them I have to take the whole bumper off. So try and avoid it!
Discussion Starter #6
thanks guys! im debating on buying a new k2 kit and starting fresh or just doing the lights i have
Discussion Starter #7
soo um
the back of the blazers seem to be running into the air box
not sure how to fix this
oh ahha u have a coupe... on my sedan i didnt have a problem with the airbox, but i did have to move my horn a little..
install a sri haha... but do u know how bad its gonna hit?? is the bumper not even gonna go back on??
it's the resonator, you can have it removed and drive it that way...it's like a poorman's CAI when you do it....there are many who drive without the resonator
Discussion Starter #10
i dont wanna remove stuff
but damn ive spent hours on these blazers and dammit i wanna run them ha
Discussion Starter #16
the box mister mail man brought
I used epoxy as a filler
fiberglass cloth as reinforcement
dont laugh this is my first retro attempt
cutoff down a hall
Purpul Plane 4ever!
not bad....no ring?
Discussion Starter #20
Any suggestions on how to align the projector within the fog?
EDIT: Thanks for the pics!!
i made a mount with a 2x6 and a couple 2x2
just scrap wood around the yard
i put that in an empty enclosed cargo trailer with tape on the front wall with inch markers on the tape left right and center
a wall in your house or garage would work too
i lit up the reflector light to mark a reference mark for cutoff
then removed the lamp from the bracket, leaving the bracket on the mount
and after cutting out back of reflector
i just lined the projector cutoff to the reference mark
taped it in place and tacked it with 5 min epoxy.
ill know better Thursday but this should work, unless i made a mistake
if your careful, you can retain the stock up/down adjustment
also i had to modify the bracket a bit, dremel to the rescue
note that i went through about $10 worth of cutoff wheels
i angled mine out just a tad to illuminate the side of the road slightly better.
any other questions
ill help if i can
im definitely not an expert at this but ill tell you what i know
1 - 20 of 46 Posts
