Hey guys, I recently hit a curb going pretty fast and Ive fixed everything else, including the outer tire rod, the lower control arm, and the rim itself. I took it into a shop cause the wheel still looked angled. They told me the spindle is bent by three degrees and is drivable but has potential to wear out tires within a couple hundred miles. He said its 400 hundred to order the spindle and have it fixed and at this point im burnt out and dont have the time to fix this last problem. I need to get the car from phili to washington dc (around 200 miles) and i wanted to know what you guys though about this? Do i need to have it done or can i drive on this for a few months till i can fix it myself?
Any help is appreciated!
P.s. can you just adjust the camber to compensate for the three degrees and drive on that??
