SPC even did it on their Rally Sentra...
Steps 4 and 5:
Balance shaft eliminator and early prototype camshafts Now, it seems like an exhaust would be a natural next step, but there was a rally coming up and eliminating the balance shafts offers some critical durability enhancements that we wanted to take advantage of. The purpose of the balance shafts is to cancel the natural imbalance of an inline four. This imbalance is minimal on a small-displacement engine, but as the pistons get bigger and heavier and the stroke increases, the imbalance gets obnoxious. This is purely a noise and vibration issue and has no effect on performance. In fact, it takes a significant amount of power to spin most balance shafts.
Most balance shafts are integrated into the block, but the QR25's are in a self-contained assembly in the oil pan. Where they're mounted, the counterweights on the shafts froth the oil like a pair of eggbeaters spinning at up to 12,400 rpm. It's unclear how detrimental this oil frothing is, but we didn't want to find out during a rally.
Jim Wolf Technology makes a kit that replaces the balance shafts with a pair of windage trays and some spacers carefully designed to cap off the oil galley that once fed the balance shaft bearings. The bolts holding the balance shafts in place also passed all the way through the lower half of the split crankcase into the engine block. In other words, they're major structural bolts, and the JWT spacers are critical to getting them back to their structural duty.
Unfortunately, there was a problem with the third-party dyno we tried to use between installation of the balance shaft kit and the first set of cams we tested, so we weren't able to produce a dyno chart of just the balance shaft gains. Jim Wolf tested the kit later on another Spec-V and found a constant 6 lb-ft gain in torque across the powerband, which equates to about 7 hp at redline.
Surprisingly, there's virtually no noticeable difference in engine vibration without the shafts. Apparently, the QR25's reciprocating bits are so light that even with the massive stroke, there isn't that much vibration. The QR25's engine mounts are also so soft, they absorb any additional vibration the shafts aren't canceling. Removing the balance shafts from the pan frees up an extra quart of space in the oil pan, bringing total capacity to 6 quarts.
We did have some unexpected problems in the two rallies following the balance shaft removal. Fuel injector wires started having fatigue failures about a quarter inch from the connectors, and one of the electronic throttle wires had a similar failure. Our best guess is that the unsupported sections of the harness were resonating, causing fatigue failures in the wires. It's not clear if this is from extra vibration from the missing balance shafts, or simply from the abuse of rallying. After replacing the harness, we zip-tied any free sections of wire either back on the connector, or to the nearest solid piece of engine. The problem has not come back.
The first in a long series of camshaft tests was next. The QR25 has no hydraulic lash adjusters, so changing cams involves an extra step of adjusting valve lash. Like any direct cam-on-bucket valvetrain, in which the cam lobe pushes directly on the valve bucket instead of using a rocker arm, this adjustment means swapping shims (or, in this case, buckets of different thickness) rather than something simple like turning an adjuster screw. Because there's only a limited range of bucket thicknesses, re-ground cams are impossible. Regrinds start with a stock cam and then grind down the base circle, which increases the bucket thickness needed to achieve the proper valve lash. Jim Wolf's cams are ground from a fresh cam billet, so the base circle is the same as stock.
All the prototype cams we tested, and whatever final cam gets produced, are designed to work with stock valve springs, at least up to the stock rev limit. Regardless, we used Jim Wolf's valve springs as insurance against valve float in the event of a red-misted over-rev during a bad downshift. Not that we ever do such things.
The QR25's variable intake cam timing eliminates valve overlap at idle, so even with cams, the car idles perfectly and is as civilized as the stock car. Most of the cams lost significant amounts of torque below 3000 rpm and didn't start making serious gains until 4000 rpm. The QR25 makes so much torque at that low engine speed, though, that the torque lost honestly wasn't missed. The engine is so torquey that in street driving (which rally cars do still have to do) we still frequently pull away from stops in second gear, even with the cams.
