1 - 4 of 4 Posts
okay so i got a an 06 civic si low mileage and just recently i noticed it was hard to put into gear. then one morning started it up tried to put it into gear but wouldnt go into gear. But when the car is off and i put it in gear while its off and turn it on the car will go in and out of gear. also when i try taking it out of reverse i have to put some force into it to get it out of gear.
2-3 gears problems is a known issue on 8th gen Si.
You are posting in the r18 engine sub forum, got to the Si sub forum for better support.
If you have a bent or broken shifter cable you won't have certain gears. The shifter will feel like they just aren't there. At least that's what it felt like in my k-series accord.
Try a gear oil change and cross your fingers. Also bleed your clutch hydraulics and check to make sure your slave cylinder isn't leaking.
1 - 4 of 4 Posts
