1 - 1 of 1 Posts
So after years of not owning a honda Nd only my truck to haul my bike to races i finally picked up a project. 09 civic si with 70k miles with a clean title. Bought it with the stock k20z3 blown a rod through the block and a trashed clutch. Initially i was going to go frank and buy a k24 block put my head on but later on found out the stock head had a bent valve also. So i sourced a jdm k24a and swapped over my rbc mani and components and started a maintenance rebuild on the k24. First part was the prb oil pump kit off afhk honda. New oem timing chain and tensioner ect. Arp head studs, basically every possible seal tensioner and bearing i could change other then the pistons and rods themselves. Competition stage 2 clutch with lwfw. After months of tearing apart and putting together on my small 1 car garage due to long hours of work and racing on weekends its finally running! Woot! Has skunk2 megapower rr exhaist with the skunk2 alpha header, intake and flashpro, hondata imf
1 - 1 of 1 Posts
