1 - 6 of 6 Posts
Morning gents
Tried and failed to remove my B pipe at the weekend , the nuts where very rounded and working in axle stands access was limited.
I plan to try again once the civic is on a ramp, what’s the best way to tackle these ?
Saw or grind it off. Or use a smaller socket and hammer it on, then loosen nuts off. If it breaks, you will need to drill the left over bolt stud off if it is stuck. It looks like it's at the point you can't avoid if you want to get it off.
Make sure everything down there is stone cold! You’ll round exhaust bolts and nuts if they are still hot, or even warm.
1 - 6 of 6 Posts
