Automatic Climate Control threads merged
1 reading
84K views 226 replies 82 participants last post by  jcob
#1 ·
Mods, if it's appropriate, please move this post into the DIY forum as I can't post there yet. As my knowledge grows, so will this post. I hope to turn it into a complete DIY eventually. Thanks!
I have spent all afternoon at techinfo.honda.com, and I have gathered a lot of information. Unfortunately, I don't have any conclusive knowledge that a retrofit is possible. However, assuming the CAN bus cooperates with us, it should be.
All of the control logic for the Automatic Climate Control system (hereafter ACC) is stored in the control panel itself. Honda refers to this panel as the 'Climate Control Unit' in their electrical schematics. Fortunately for us, all of the pins we currently have on our standard 'Heater Control Panel' (Honda's term for the non-ACC control panel) have direct correlations to the pins on the ACC system. So, we will only have to add additional wires to the new panel, we shouldn't need to do anything but basic splicing to our existing wiring harness.
The catch: the ACC control panel has a connection to the car's D-CAN bus (the non-ACC system doesn't). While our non-IMA FG's do utilize the D-CAN bus, it's possible that the ACC control panel will not initialize or operate properly unless it gets certain packets across that bus. The hybrid utilizes a dual-stage electric/mechanical AC compressor (so the coolant still flows when IMA has the engine off) that our cars do not have. This compressor and the IMA system use the D-CAN bus to communicate things like engine power status (I.E. the Power Module tells the ACC system to activate the electric compressor because it has shut down the engine), among other things. While it's possible to spoof the CAN bus with a computer, I am guessing that's more than most people will want to do. ;)
Thanks to jbbrann's suggestion, I will check out the CDM Acura CSX, as it might have a compatible ACC that will render all my work today moot. :banghead:
It's also possible that Honda engineers did a really good job, and engineered the panel to work on models that are not equipped with IMA. This makes sense to me, as it would allow them to use the same ACC control panel across non-IMA models, and would cut their costs. Unfortunately, there is no way to find out without trying.
Aside from the D-CAN connection, there is only one sensor that will need to be spoofed with a resistor (the Heater Core Temp sensor, or you could just buy one and install it along with the other sensors), and we might also need to buy a new air recirculation motor (IMA cars have additional pins, and there is a different part number for the motor at hondaautomotiveparts.com). Additionally, we will need to splice a line into our exterior temp sensor, and we will need to add the cabin moisture/temp sensor and the sun load sensor. All that should be really easy.
If anyone is interested in helping me with this (Maybe someone in the bay area that owns a hybrid? :D), here is all of the info I have gathered so far:
http://dump.aethion.net/Cars/Schematics
More as it happens, back to you Tom.
#6 ·
thanks for all the info mate.
I'm in Sydney Australia, but I think out cars are pretty much the same, except for having the dashboard, and steering wheel the other way around.
Let me know if i can help somehow with this.
I would have tried it already except Honda Australia, does not want to sell the Climate control parts, and I'd have to buy them from the States.
Cheers.
#9 ·
I liked the ACC on my 99 TL. I usually just set the temp and manaully set a low fan speed, then let the system takes care of the rest. I find it worked quite well and I hardly needed to adjust the temp again on the same trip
I'm getting my CSX with navi this friday and I can't wait to set temp and fan speed on the ACC with voice commands :D
#10 ·
ttheisen93 said:
I've had two cars with auto climate control and I always ended up using manual anyway because the auto mode was annoying. Just not sure this is going to be worth the effort. Have you had it before and really liked it?
same here, only 1 car with it was enough for me. I found myself having to change something or other on the panel much more on the auto system then a normal manual one. With the auto, I was always turning off the a/c compressor if I didnt need it, changing temps, over riding fan speeds, etc.
#11 ·
I currently own 2 cars with ACC, and every car all the way back to my 91 CRX Si has had it. Really, it's just a matter of personal preference. I learned that, usually, if you just leave it alone, it does a pretty good job of maintaining a static temp. For me, I just absolutely fricking HATE having to tweak the temp knob manually. It seems like I always go from too hot to too cold, and back again.
I have done some research on the CSX, and I am almost certain that this will be a fairly simple plug-and-play type mod. We will need to add two cabin sensors, replace our recirculation motor, run a couple wires under the dash, and build a harness connector. Total cost of parts will be around $450 US.
I have no money at the moment, but once I do, I will get the part and do a write up for anyone that wants it.
#13 ·
I would certainly be intrested. I had it in my Mini and I have it in my Saab. I love it. Set and forget. If we could do it as plug and play from the CSX parts bin for less than $500 I would do it. I won't do it if we have to splice wires. honestly though not sure how long we will keep the car. In two years I think we will see much better hybrids that utilize plug in technology. If that happens then I will sell the Civic.
#24 ·
Alfas were sold in the US until 1995. I have a 1985 GTV6 sitting in my driveway. A friend of mine became obsessed with everything Alfa, and actually started a business collecting parts, building engines, restoring anything he could possibly find. I was surprised to find so many around once you actually start looking out for them.
