1 - 3 of 3 Posts
Hi looking to see if I can change from a 17x7 45 offset, to a different wheel 17x7 55 offset. Will I still be legal in G stock? Anything else I need to know about the offset change? Thanks
13.4 WHEELS
Any type wheel may be used provided it complies with the following: it
is the same width and diameter as standard, and as installed (including
wheel spacers if applicable) it does not have an offset more than
+/- 0.25 inch from a standard wheel for the car. The resultant change in
track dimensions is allowed.
+/- .25 inches which is equal to +/- 6.35mm offset.
No it's not legal unless you added wheel spacers.
If you're in the market for a light GS wheel PM me. I just did way too much research on this before buying some GS stock compliant 17x7's at 48 offset as race wheels with a set of V710's.
1 - 3 of 3 Posts
