1 - 20 of 20 Posts
My 2007 Si Coupe seems to have a slight pull to the left,which is the opposite(spell?) of what most have.I had the tires rotated and balanced today and it didn't change.Will the Honda dealer check this for me under warranty and for free?Anyway,my last car did the same thing even after three alignments and new tires.I could actually shift into the left lane just by turning loose of the wheel.I sold it and bought the Honda,but the Honda is doing the same.I would rather have the car pull to the right and not the left.Any advise?
Scrodums
I don't believe it will be an alignment or balancing issue. There was a TSB I've glanced over before and it addressed this issue. They had to disassemble the steering rack (don't quote me on this...) or something steering related and readjusted the steering wheel.
Well,I just made an appointment for Monday mourning.Having the alignment checked should be under warranty,right?
I am getting kind of worried about the car going left.As I said I sold my last car because of it.I did several searches and all complaints are about the car pulling right,which is normal to some extent.Hopefully the dealer will be able to find something and fix it.
Mine pulls to the left, especially since putting my 18s on. This is a common issue?
Pulling in any direction is never a normal condition. Warranty covers the alignment up to 12 months or 12,000 miles under manufacturer defect. You shouldn't charged anything to check or correct alignment under these conditions... and it's never something a technician minds doing, because it pays very well to do a warranty alignment (usually).
My steering wheel has been off center from the day I bought my car... but I'm a tech, and I know I can fix it myself I haven't taken it back... had just been waiting to get the 06-07 updates in our alignment machine before I fix mine... that happened two weeks ago... just waiting for work to slow down a little before I straighten her up.
Take it to your Honda dealer... tell them your problem... drive with the tech if you need to, so they'll know what exactly your problem is (be it mechanical or psychological) and get it fixed before it's out of Warranty.
I had the same issues and the bastards charged me for allignment.
Drove off and it was though as nothing had been done!
2006 Honda Civic Si L4-2.0L
Vehicle Level Technical Service Bulletins All Technical Service Bulletins Steering/Suspension - Vehicle Pull/Drift To One Side
Notes
06-068
January 12, 2007
Applies To: ALL 1999-07 Models
Vehicle Pulling or Drifting
(Supersedes 06-068, dated November 18, 2006, to update the information marked by the black bars)
SYMPTOM
While driving on a straight road, the vehicle pulls or drifts to the right or left.
BACKGROUND
New tools were developed to help you diagnose and correct a pulling and/or steering wheel off-center issue. There is a diagnosis worksheet included to take on your test-drive and record your findings. These values are used to build the 15-digit DTC (diagnostic trouble code) that is required for your warranty claim. The last step in each repair procedure helps you create the correct code.
In the rare case that you have to repair a vehicle that pulls and has the steering wheel off-center, use REPAIR PROCEDURE B to file your warranty claim.
PROBABLE CAUSES
Several conditions can cause the vehicle to pull or drift:
^ Wheel alignment
^ Tires
^ Steering wheel off-center (no pulling or drifting, but a customer may believe this is the case)
CORRECTIVE ACTION
Diagnose the problem using the special tools and the worksheet on page 4 that guides you to one of four repair procedures.
TOOL INFORMATION
WARRANTY CLAIM INFORMATION
In warranty:
The normal warranty applies.
Failed Part: P/N 53560-SDA-A01
H/C 7139652
Defect Code: 07406
Symptom Code: 03602
Skill Level: Repair Technician
Diagnostic Trouble
Code: To create the 15-digit DTC, see
the applicable repair procedure.
Out of warranty:
Any repair performed after warranty expiration may be eligible for goodwill consideration by the District Parts and Service Manager or your Zone Office. You must request consideration, and get a decision, before starting work.
TOOL INFORMATION
Holding Force Gauge
The holding force gauge measures the amount of the pull on the vehicle. It is a bracket that counts as one weight, plus five removable weights.
During the test-drive, attach the bracket and the weights to the steering wheel on the side opposite the pulling direction. For example, if the vehicle pulls to the right, attach the bracket and weights to the left side of the steering wheel. Start with the maximum amount of weight on the steering wheel, and remove the weights until the vehicle drives in a straight line.
When recording the pull on the worksheet, write down the direction of the pull (left or right) and the number of weights required to balance the pull (one through six). For example, you have the bracket and two weights on the steering wheel. Record this as three weights.
Road Crown Gauge
The road crown gauge measures the amount of road crown. Almost all roads have a crown to help drain water during rainstorms. Use the suction cup to attach the road crown gauge bracket to the vehicle in a vertical position. If necessary, bend the bracket until the gauge is vertical. Once you attach and align the road crown gauge, calibrate the gauge to zero. There are two ways to calibrate the gauge:
^ Park the vehicle on a level surface, like an alignment rack, and calibrate the gauge by moving the gauge until the ball is on the zero mark.
^ If you do not have a perfectly flat surface, park the vehicle on a reasonably flat surface and note the gauge reading. Turn the vehicle 1800 and, with the tires in the same spot, note the new gauge reading. Then move the gauge half of the difference. Example, your first reading is +3 and after moving the vehicle, the gauge reads -1. The difference is 4 degrees. Position the gauge to read +1.
NOTE :You must calibrate the gauge with the same weight in the vehicle that you will use for the test-drive. If you plan to have an assistant help you during the test drive, calibrate the gauge while both of you are sitting in the vehicle.
Steering Wheel Offset Gauge
The steering wheel offset gauge is a sticker that attaches to the steering wheel and the steering column cover. Place the sticker on the steering wheel when the steering wheel is straight. When you test-drive the vehicle, you can read how many millimeters the steering wheel is off-center.
NOTE :If the vehicle is pulling, repairing the pull may correct the steering wheel offset.
DIAGNOSTIC WORKSHEET
Disclaimer
© 2007 ALLDATA LLC. All rights reserved.
Terms of Use
we need to pay to see the Honda TSB on alldata
How can I show the guys at the dealership that there's something posted on TSB for specific issue if they don't know what i am talking about?... without paying alldata
I have a slight pulling to the left while driving. It has been that way since I got the car. Might have to have it checked.
my car just started pulling right recently but i've never seen a TSB on it. Do you have a website where i can find that info.
Discussion Starter #20
Well,at least I'm not the only one.Pulling to the left can be more dangerous that pulling to the right.If your not paying attention you can go head on into oncoming traffic,or sideswipe someone.If it goes to the right(actually,it should,slightly) you may run off the road,but have less of a chance of hitting someone else.Everyone else complains about right hand pull,but that is normal to some extent.Actually,it shouldn't pull at all,but it should drift after awhile due to the crown.
1 - 20 of 20 Posts
