Yeah. IIRC, the negative terminal and positive terminal has a little nut and bolt that allows the terminal to stay on the battery. I just used those to connect to the battery. Works fine, since it's still exposed metal.brdhouse said:So, just find some bolts and random holes and ground them that way? the gold plugs are not large enough to fit around the neg terminal anyway... but in principle, there needs to be a ground, right? and that's most likely what these are, right?
haha. that's what I was just doing.striker_1818 said:show me a picture.
Most likely each ballast has its own ground.
That's how it seems to me.Izzy said:So, the wire with the O-ring connects the two ballasts to the positive, while that small prong comes out of the two ballasts? Ground.
You do know why the harness is there, correct?jackolee said:i got my kit from xenon depot too and i didnt even need to use the whole kit only the ballasts
