1 - 3 of 3 Posts
..a clutch lock w/ quick release? I heard something about it in another forum, but can't remember which one? I here there a great deterant to theft.
snip the wire on the clutch pedal sensor (the one that grounds the wire when the clutch is pushed in... then run the wires to another switch.
Now the switch has to be 'on' for the clutch pedal to ground the wire :)
make sure you follow the wire far enough in the dash so no one who quickly looks spots what you did!
or you can wire a switch for the fuel pump. You can also just pop the hood and disconnect the ignition wire from giving power to the spark plug coils.
1 - 3 of 3 Posts
