1 - 20 of 31 Posts
Installing a Skunk2 Mega Power 60MM Cat-back exhaust???? :eek:hnoes:
Or is it really easy to do? If it is, what would I need in order to install it?
Thanks in advance!
:popcorn:
Thanks in advance!
:popcorn:
Easy stuff man. as long as you have a jack and some jack stands it can be done.
Zeuceone said:
jack
jack stands
wd40
and some ratchets.
well yeah I didn't think I would have to say ratchets lol. But wd-40 is good for the rubber hangers. but not really needed. We hung Davids exhaust without wd-40
If you need help man let me know I'm always down for an install.
Thanks a lot guys, I will try to see if I can do it myself, but if I feel that I'm too nub for this, I'll try to holla at ya :)
Discussion Starter #6
I just received the exhaust!! :)
But, I don't have the instructions... any help on this one?
Discussion Starter #8
Yah, I got a good look at underneath the car... I'm just a little hesitant to do this thing solo since I haven't done this before. I'll give it a go tomorrow when I have some free time
yea man just get a jack and jackstands. autozone had a hell of a deal on them a 2 ton hydraulic jack and 2 jack stands for 25 bucks...
Discussion Starter #10
I already have a floor jack and 2 jack stands... do I need more than 2 jack stands?
no you don't, just a jack or two -stands aren't really needed. you should be fine. start from taking out the passenger rear wheel and undo the cat..... work yourself in towards the center of the car... make sure you have the tools... peace
Discussion Starter #16
Aight, I'll try to do it without removing the wheel first :)
Where should I place the jack and jack stands? on the side or the rear?
Mikey6p said:
Good luck getting the cat bolts off. Thats the only roadblock. No wheels need to come off the car.
just don't be a whimp mikey... or let me do it i can break anything... especially tools. fu*king cheap tools breaking with too much force
hahaha. we just did one matt, mikey and i. same exhaust. good luck getting the cat bolts off, those were the only roadblock like mikey said.
Also, I see no point in having the rear passenger wheel off, clearence was fine.
guess you need my touch. if it was stripping you were using the wrong socket or wrong angle. just admit it mikey come on
1 - 20 of 31 Posts
