hey, first post so don't rip me to hard.
have a Kraftwerk's on my 8th gen si
My problem isn't with the pulley itself but the bolt that holds the pulley in its place. I have gone through 2 bolts now as they have both broken off inside of the mounting bracket for the rotrex. yes, I tried to extract it because the Allen key below is stripped anyways it's in the shop to get both of those bolts out.
my question is... what is the best solution would be to fix this problem.
belt tension isn't the issue it is tight enough that i won't get belt slippage and still get 10psi of boost. but not loose enough for belt slippage.
are there any relocation brackets that work with the Kraftwerk's?
my theory has to do with the tensioner taking up alot of the bolt and how little there is left of the bolt that goes into the bracket. causing a leverage issue and strain on the bolt during load. as the bolt is only braking off between the tensioner and the bracket.
any help is good help at this point. will be going for more power soon and can't have this ever be an issue again.
