Will this also affect my intake pressure ? as my intake pressure gauge now is making totally different readings then before...yup less oxygen=less power
The only way to compensate for alt and low pressure that a car can do is to reduce the air/fuel ratio. The only other way would be to compress the air back down to a sea level pressure, that would be like a small supercharger, and cars dont have anything like that unless it is supercharged.Cars have altitude compensators.
:rotfl: ROTFLMAO. Please doctor, explain how these "altitude compensators" work.Cars have altitude compensators.
Then there's the whole humidity card to play (water molecules weigh less than the surrounding "air" molecules and as such cause the air to be less dense). As any pilot can tell you, any combination of heat and/or humidity and/or altitude can make it difficult to get a fully loaded Cessna 172 off the ground.So if its hot and hi alt, Now your ihave a double screw job.
I think you got it backwards. Humidity (water) is more dense and would increase a air charge. As far as the pilot question. Yes I do fly DC-10 aircraft for a living and we do not take humidity in account when calculating aircraft performance, its only a plus. Thats why some older aircraft like the older KC-135A models and jets from the 50's-early 60's used water injection strait into the engine to increase the air charge.Then there's the whole humidity card to play (water molecules weigh less than the surrounding "air" molecules and as such cause the air to be less dense). As any pilot can tell you, any combination of heat and/or humidity and/or altitude can make it difficult to get a fully loaded Cessna 172 off the ground.
To adjust your phrase a bit, "So if its hot, humid and hi alt, now you have a triple screw job." :thumb:
Ummm, no, I have it correct, water vapor is far less dense than the air it is mixed with.I think you got it backwards. Humidity (water) is more dense and would increase a air charge. As far as the pilot question. Yes I do fly DC-10 aircraft for a living and we do not take humidity in account when calculating aircraft performance, its only a plus. Thats why some older aircraft like the older KC-135A models and jets from the 50's-early 60's used water injection strait into the engine to increase the air charge.
http://en.wikipedia.org/wiki/Density_altitude
FWIW, I used to fly an old O-300 powered 172 out of an airport in New Jersey (altitude 182') and am very versed at calculating the Density Altitude. Going over my log I see that one flight in August a few years back had a Density Altitude of a whopping 3,816'. Why? Because of the humidity. That particular day the OAT was 97 and the dew point was 95, however, if the dew point had been at a more normal 70 or so, the Density altitude would have been only 3,414, a difference of over 400' in altitude.
FWIW #2, on a training flight from that same airport the OAT was -20 and the dew point was -50, equating to a density altitude of 5,019 feet below sea level. That day I got the plane off the ground in about 30' at a whopping 25 mph. I was practicing departure stalls over a reservoir up in the mountains and at one point flying into a fairly stiff headwind, I was actually watching the mountains passing me as I had a negative ground speed.
A car's engine computer does in fact compensate for altitude by adjusting the air/fuel mixture accordingly to keep the engine from running poorly at different altitudes.Cars have altitude compensators.
