Hey guys, I need a bit of advice here.
My current audio setup as of right now:
Alpine CDA-9886
Two 12" RE Audio SEx subwoofers
Ultra Linear UL2800D 1600w amp, running the subs in 2ch at 600w (as advertised at least, eBay amp, gets the job done)
This wiring kit
JL Audio XR650 CSi Components
I got a Phoenix Gold Octane-R 5.0:4 amp to power the components. I have a few questions I'd like to be answered and statements I'd like evaluated regarding installing the amp.
What should I upgrade in my electrical system? Already planning on getting a Yellow Top but should I really take the effort to upgrade the "Big 3"?
What is the least necessary gauge power and ground wire I should use? I'm fine with using 4 but I'd use 8 if it's already overkill.
I have my subs' amp grounded to a bolt behind the backseat and it is working fine. Should I use the same ground for the amp or should I run both grounds back to the battery? I have heard of "ground loops" and I am not in the mood for that. Pretty sure Hans will say run them back to the battery but it doesn't hurt to ask. =P
Preface for the next question: My friend utilized my amp bypass harness and basically connected the crossovers and components with the stock wiring. Can I get away with just running the wires from my amp to the crossovers and get the same sound? If not then...
What is an optimal gauge of wire to use for the speakers? I am prepared to devote a weekend to rewiring the whole car.
That should be it for now, if I remember anything I'll ask. Thank you very much in advance for any help given.
Alpine CDA-9886
This wiring kit
