1 - 9 of 9 Posts
Just got a shipment in of the ACT clutch and flywheel kits for the 06 + Si's
If you're looking for a cost effective upgrade from stock, without a clutch that is nasty to drive, then the HDMM or SS units are for you. Each is good for 252 ft lbs of torque (at the crank)
HD-MM - ACT's Modified Street friction surface is SFI certified and is an excellent choice for lightly modified, street driven cars. The MM disc provides quicker engagement than a stock surface and is quiet compared to other, more aggressive, friction surfaces. The sprung hub uses bushings and cone springs similar to OEM clutch discs. This creates frictional dampening which improves clutch life and reduces noise.This clutch has very smooth engagement and ideal for a daily driver.
HD-SS - similar properties to the MM disk, but grabs a bit harder. Our most popular unit for these cars.
If you need more torque capacity, and don't mind a very grabby clutch, then we have the Xtreme pressure plate. These feature more torque capacity than the HD units (85% more than stock), and hold upwards of 338 ft/lbs of torque.
If you're a drag racer, and need a clutch with quick engagement, but is still streetable, then we also have the 6 puck disk available. The ACT 6-Puck Sprung Hub Race Disc is SFI certified, so it is legal for all forms of racing that require SFI compliance. An ACT G6 race disc has a very durable friction surface with good spline life. The G6 was designed for a highly modified car that is drive to, on and from the track, as long as harsher engagement is acceptable. The sprung hub helps to reduce driveline shock and be relatively quiet compared to an unsprung hub, though the G6 can still be noisier than a full face disc and will have some chatter.
We've also got the ACT flywheels ready to go! These come in 2 flavors, Streetlight and Prolight. Both are chromoly 1 piece units, so they can be resurfaced down the road like a conventional flywheel without having to replace the friction surface. The Streetlight weighs 11.4 lbs, the Prolight weighs 8.4 lbs.
Prices start at $430 for the above clutches (for the 6 puck unit) and go up from there. Combo deals with flywheels are in stock and ready to go too!
in the market for an oem replacement clutch so a stage 1 type will do, and a lightweight flywheel...can you pm a package? thnx
1 - 9 of 9 Posts
