Ac
325 Views 2 Replies 3 Participants Last post by  atomsmasher87
I've run into my first problem with my 07 si 2dr. I found out my ac doesn't work. I first recharged it, tested for any leaks, checked the fuse and relay but the compressor is still not getting power. I started to think my compressor is bad but then I realized I haven't checked the pressure switch yet.
would anyone else have another idea before I go ahead and order a compressor if the pressure switch works?
1 - 3 of 3 Posts
Check if your clutch is spinning. I bet if you tap the clutch carefully with a screwdriver while you have the AC on it will kick on.
  • Like
Reactions: 1
Go with an Oreilly compressor, OEM compressors aren't that good,,,, and order a new condenser as you should replace both
1 - 3 of 3 Posts
