1 - 1 of 1 Posts
Hi;
The car is Honda CIVIC FD4 2011.
On every morning when putting the shaft on R take a while then hard engaged also when but into D hard engaged & the car start from the high gear
When I turned OFF then ON everything is okay
No check engine, when the problem happens & check the DTC
A/T Clutch Pressure Control Solenoid Valve A performance Stuck OFF
No D blinking & the DTC also not appear when turning off & on
Have you solved this issue brother? Please give me a procedure on how to solve this issue.
1 - 1 of 1 Posts
