1 - 4 of 4 Posts
Hey folks. I want to set up my car for autocross so that I can hit up some events this summer, and I've got a couple of questions about the suspension upgrades I'm looking to do. I tried looking up the info I need, but no website seems to want to provide it...
Do Neuspeed Race Springs have a linear spring rate?
- if not can anyone suggest a comparable spring that does?
Do Koni Yellows have independently adjustable bump and rebound?
- if not, can anyone suggest a comparable shock that does?
Thanks!! :hail:
Neuspeed Race over lowers your car for increases in handling IMO. (anything past 1.5" less stock height)
1. OTS KONI Sports (Yellows) are S/A. Rebound only adjustable. Front are inserts. ~$650 front and rear.
2. Contact Redshift Motorsports or KONI direct for D/A. Rebound and Compression adjusted separately. Rear dampers are ~$650 ea. Front dampers ~$450 ea.
3. If you want true linear springs set-up contact Redshift Motorsports for their KONI D/A set-up. That set-up with optional ASR front camber plate, and Swift Springs (coilover race springs choosing the rates you require) is ~$3,500.
1 - 4 of 4 Posts
