1 - 7 of 7 Posts
So... I changed my plugs today.. Yes I ensured gappage was correct...
Now my boost guage flashes green/yellow around the outside and the middle says ErP... Correct me if I'm wrong, but I just need it retuned correct?
Well ErP means: If the external sensor is shorted or disconnected, the LED lights will flash
red and the center digits will display “ErP”. The error code will not activate when using
the internal pressure sensor.
I guess I know that problem! Now to get the retune back to 8 1/2 psi since I got a new MAF
Discussion Starter · #7 ·
I'm learning about things on my car... turbo and amature are two words that shouldn't be said in the same sentence. I want to ensure I keep the correct boost levels so I don't mess anything up...
WHen I reset it, the gauge said I was boosting to 56 KPA... which I orginally thought was PSI... I nearly **** a brick.
1 - 7 of 7 Posts
