My '08 has an issue where that happens sometimes, usually after changing from AC to defrost or truning the temp from max cold setting to warm or hot.. (S, Florida that is not very often) then it won't go back to cold air again,,
Seems like the Air-Mix motor is the issue... if I run the self test diags it runs thru the test with no errors and fixes itself.
With Ignition switch Off, Key inserted:
1. Turn the fan switch OFF.
2. Press and hold the recirculation control switch and the rear window defogger switch down.
3. Turn the ignition switch On, (II setting).
4. Release both switches. The recirculation indicator and the rear window defogger indicator come on. The recirculation indicator goes off 3 seconds later and the A/C indicator comes on. then the self-diagnosis will begin. About 10 seconds later, the self-diagnosis will finish and the A/C indicator goes off.
If any trouble is found. the recirculation indicator blinks the diagnostic trouble code (DTC) to indicate a faulty circuit or component.
If the system is OK, the recirculation indicator stays off.
