1 - 20 of 29 Posts
Administrator
Discussion Starter #1 (Edited by Moderator)
Congrats to May 2014 Ride of the Month Winner: fg2taffysi
Photo Credit The Sauce Spot
Engine / Performance Modifications
*IMT Custom Blower Pulley
*IMT Big Bore Inlet
*IMT Kool Boost 2.25 Charge-Air Cooler
*IMT Custom High Density Core
*IMT 1.00" Thick Phenolic Supercharger Spacer
*IMT Heat Exchanger
*Hybrid Racing Fuel Rail
*Hybrid Racing Fuel Pressure Gauge
*Hybrid Racing Shifter Cable Bushings
*Hybrid Racing Slim oil cap
*Hybrid Racing Coolant Temp Sensor Adapter (used for idle air assist delete)
*Hybrid Racing Reservoir Cover
*Wire-Worx Engine Harness
*Wire-Worx Ground Wires
*Skunk 2 72mm Throttle Body With 80mm Inlet
*Skunk 2 Low Profile Valve Cover Hardware
*Skunk 2 Mega Power Header
*Skunk 2 Intake Manifold Gasket
*Skunk 2 Short Shifter
*Ct-Engineering Supercharger Manifold Powder Coated Super Chrome
*Ct-Engineering Idler Pulley Bracket & Pulleys
*Speed Factory Racing Polished Coil Pack Cover
*Speedfactory Tuning & Race Fabrication Custom Coolant Overflow
*Injector Dynamics 1000 cc Injectors
*Hondata FlashPro
*Hondata 4 Bar Map Sensor
*Sheepey INC Custom Catch Can
*Trac Tuff Water By Pass Adapter
*T1r race devlopment IAT Sensor
*k24 Crank Pulley
*Walbro 255 fuel pump
*Full Race 3 Inch Exhaust
*Custom 3.5 Inch Intake
*Vibrant 3.5 - 3.25 Silicone Reducer
*Vibrant T Clamps
*Vibrant -An Fittings
*Vibrant -An Braided Hose
*Aem Dry Filter With Hydro Shield
*Clutchmasters Stage 2 clutch
*Valve Cover Powder Coated Black Chrome
*Motor Mounts Powder Coated Super Chrome
*Downstar v.3 Black Hardware - on coil pack cover, coolant fill neck, coolant overflow, radiator bracket, upper radiator support, fenders, hood hinge, ground wires, ac line bracket
*Downstar Motor Mount Bolts - with black beauty washers
*Downstar Supercharger Manifold Bolts - with black beauty washers
*Downstar Idler Pulley Bracket Bolts -with black beauty washers
*Downstar Water Bypass Adapter Bolts - with black beauty washers
*Password Jdm Battery Relocation Kit
*Odyssey 680 Battery
*AEM Wide Band UEGO
*AEM Boost Gauge
*Boomba Racing Motor Mounts
*JDM Dipstick
*Mugen Radiator Cap
Wheels / Suspension Modifications
*17x8 40 offset Enkei Gtc01 Hypersilver
*225 45 17 Nitto Invos
*(Track set up) Team dynamics 15x7 with m&h 24.5 x 8 slicks, m&h 3.6/24 x 15 skinnies on the rear.
*Arp extend wheel studs
*949 Racing Extended Lug Nuts
*D2 coilovers
*SPC Rear Camber Arms
*Beaks Rear Lower Tie Bar
*StopTech Street Performance Brake Pads
*StopTech Drilled & Slotted Rotors
Exterior Modifications
*HFP Front Lip
*JDM Red Emblems
*Trunk De badged
*Grfxp Red Tail Light Overlays
*Grfxp Red Chrome / Black Emblem Overlays
*Front Grill Painted Black
*10k HID Headlights
*3k HID Fogs
*Yellow Fog Light Lenses
*Yellow DRL
*LED License Plate Bulbs
*20% Tint
*Window Visors
*Clear 3rd Brake Light
Interior / I.C.E. Modifications
*Hybrid Racing Shift Knob
*Grfxp 3.5 inch Shifter Extender
*Red Stitched Shift Boot
*Auto Meter 2 Gauge Panel
*Joes Racing Switch Panel
*Red Llyod Floor Mats
*Pioneer Double Din Radio
*Pioneer Rear View Camera
http://www.8thcivic.com/forums/car-builds/228897-fg2taffysi-build.html
Instagram @fg2taffysi
No unfortunately. We just had a baby girl :dance: last week, so i'll be sitting this year out.
I see you at Evans meet for sure.:wavey:
Congrats on your baby girl! Sounds good for the Evans meet !
Super clean and super fast. :vtec:
got a couple more things to make it a little cleaner coming soon! and of course faster!
1 - 20 of 29 Posts
