800,000+ miles and still going strong
659809 Views 1834 Replies 633 Participants Last post by  MaXpeedingRods
Mileage update: Feb 11, 2011
600,447 miles
I have a 2006 Honda Civic LX sedan 5spd manual, I purchased it used from a local Honda dealer with 22,000 miles on the odometer on 05/26/2007.
It's currently at 203,284 miles, mostly interstate/parkway at 75 mph (occasional 110 + mph) but it still has a lot of city miles as well. Over 90% of the miles were with cargo in the trunk and back seat (rear seat cushion removed for extra height) comparable to 2 passengers in the back.
When I first purchased the car I was getting around 42 mpg but then sometime down the road it dropped to it's current average of 34 mpg (I have no idea why it dropped).
Sometime in June of 2007 I hit a separated tire tread form a semi that was coiled in the middle of the road (newly paved - black) in the middle of the night at approximately 75 mph, it felt like I hit a dog -- it did over $3,000 in damage: front bumper tore in two (replaced), A/C condenser destroyed (replaced), kinked A/C line (replaced), washer reservoir cracked (replaced), passenger side sway bar bracket on lower control arm bent (Dealership actually said the sway bar itself was bent, body shop said otherwise -- bracket was just bent back into place), and internal gearing of the steering rack was damaged (replaced rack assembly).
A deer ran into the passenger side of the car while I was doing about 60 mph. It shattered the rear view mirror glass (absolutely no damage to the housing or the housing paint) and put a good size dent in the rear quarter panel (no damage to the paint).
An oncoming car was across the center line on a curvy back road, our rear view mirrors hit (thank god that's all the contact our cars made) shattering the mirror glass but again, absolutely no damage to the housing or housing paint (these f#ckers are built :p)
Paint is in superb condition, no cracks, chips, or fading. Windshield is another story, countless chips and a half circle crack in the upper passenger side (g*d [email protected] dump trucks!!!!!). Factory tint (at least I believe it's factory tint) is in mint condition, no peeling or bubbling. Interior is mint expect for shoe scuff marks on the passenger dash board thanks to my fiance and the silver paint is wearing off of my shift knob. There's no fading of the plastic and the upholstery is still in mint condition.
I have always used Mobile 1 full synthetic 5w20 motor oil with a K&N hp-1010 oil filter, I change the oil approximately 1,000 miles past the maintenance minder. I've just recently started using Lucas oil stabilizer. The only parts I've replaced have been the spark plugs (NGK laser iridiums at 80,000 miles), Duralast Gold - lifetime warranty :p - front brake pads at 120,000 and 180,000 miles (it's impossible to find rear shoes that actually fit from any of the local auto parts stores, they were all too wide -- you can get them from Honda, but they're $15 a piece), Tokico shocks/struts at 180,000 miles (absolutely love them -- still have factory springs though, but plan to drop it with Eibach Sportlines and Skunk2 control arms), and got the rear upper control arms replaced under warranty (new alignment specs) at 190,000 miles (they paid for labor and parts, I had to pay for the alignment) I think the car looks much better with practically zero rear camber, and I love the way it handles now. I have not replaced any belts or hoses yet but will replace them soon along with a coolant and brake flush, new full synthetic gear oil and full synthetic Lucas oil stabilizer for the manual tranny, and a valve clearance adjustment (slight ticking at idle). The engine burns about half a quart of oil per oil change (has always done this since I bought it). Other than the ticking at idle, the engine is silent but idle is a bit rough (I think I need to get the idle speed adjusted -- anyone know how to do this, or should I just have the shop do it?). The factory clutch is still holding strong with no noises from the bearings or tranny.
I absolutely love this car and have had no other problems that I can think of at this time. If you have any questions feel free to ask.
901 - 920 of 1835 Posts
To be honest, I don't keep maintenance logs. I've posted most of the major stuff in this thread. Right now the only maintenance I do is rotate the tires every 6,000 - 8,000 miles, change the oil and MTF every 20,000 miles, and top off the coolant whenever I remember to check it.
Finally installed the new a/c compressor yesterday. It wasn't too bad until I tried getting the serpentine belt back on, it took 3 hours (just to reinstall the belt, not including the compressor installation) and the help of friend. I'll be installing the condenser and flushing the system tomorrow, I'm also purchasing my first air compressor so I can blow out the a/c flush solvent (can't wait to get an impact wrench for my Jeep :dancing:)
Just curious...have you replaced your front or rear stabilizer links yet? If so, what condition were they in? I design stabilizer links for a living, but not for the supplier that does links for Honda. Just wondering.
still have the original links, haven't had any trouble with em.
It's currently at 512,000 miles.
I wonder what happens when you pass 999,999.9 miles.
It'll overflow and go back to zero :dance:
(Computer Science reference. Forgive the geeky impulse.)
haha, if it really did that then it would have a great resell value
:rotfl: he could put like 100,000 miles on it again, and the resale value will go back up :giggle:
crazy! the guy who did the undercoat and prep for my 07 at the dealership had an old 89 civic that he bought new. he lives out in the country compared to where he works and drives his civic back and forth every day. he rolled over 1,000,000 kms, it went back to zero and he was back up to 300,000 kms when he showed me. he also said it never broke down on him once and only things he's replaced are normal wear and tear parts like brakes and such. no, i don't have any proof but i just wanted to contribute this for some reason lol
I wonder if the computer still keeps track of the mileage even though the display doesn't have enough digits. so then once someone passes a million miles like 1 million and 1 then change the units to kilometers, it might not add up to one mile but actually show the converted value.
I dont think Honda invested much time into the mileage display. Only 1 or 2 people will ever reach a million miles on this car.... let alone 300+
holy crap you're nuts...!
can u update ur OP ? I don't want to read through millions of pages, but i'm intereted to see what kinda maintenance you've done
I am thinking they've programmed it to have an overflow variable that adds 1 to itself every time 999,999.99 is exceeded. Then the odometer resets to zero. Then they check by hooking it up to a computer or something. It doesn't take much code and is just common sense programming.
Nah man, transmission fluids from different companies are totally different.
A transmission fluid has to do a few things quite well, keep the components cool, not break down quickly in extreme heat, be thin enough to fit in between the gears, but not so thick that it damages the gears.
Redline must be better. If you really want to look into it, I suggest googling Bob the Oil Guy
and uhh lubricate them? i think this is what u meant by the last two things but ya
wheres the proof i smell b.s
Yes, the fact this thread has garnered 46 pages and still hasn't been locked is BS. :facepalm:
Look through the threads, he posted pictures of his odometer.
Get the Ingersoll Rand 2135 QTiMAX. I just bought one. The Q stands for Quiet tool and it is the quietest gun i've ever heard. It's also really light. IR claims 780 foot-pounds of reverse torque and 1,100 foot-pounds of nut-busting torque
It's cheap on ebay.
Damn man you can't be THAT lazy
look at post #876 & #898
this thread makes me feel better about my wife driving 2500 miles a month in her new civic lol
It's cheap on ebay.
That's a sweet impact wrench, but it's way out of my price range. I'm looking at a $100 one from Harbor Freight that hits up to 650 ft. lbs (adjustable from 40-400 ft. lbs) and only uses 4.7 CFM. The IR uses 24 CFM and my little 10 gallon compressor only puts out 5.6 CFM, lol.
