Shifting from 5th to 6th, do you pull straight down and sorta let the shiter drop into 6th gear? or do you need to sorta push to the right and then pull it into 6th?
Im asking because I was passing a guy in 5th, I noticed that when I went to put it back into 6th gear I went into 4th gear instead (high rev for a second but I pushed in the clutch as soon as I noticed I was in the wronig gear). I would think that a slight pull straight down from 5th would engage it into the right gear (6th).
Your thoughts on how you shift from 5th to 6th, do you lightly pull straight down or do you push to the right and then lightly pull it into 6th?
