1 - 8 of 8 Posts
52 is pretty far in... 48 would be better but i think 45 is best... but i think it depends alot on your suspension setup and wheel size
for what its worth im running 18X7.5's w/ 42mm offset... stock springs and 225/40/18 tires
Discussion Starter #6
What are the other dimensions of the wheel? Diameter? Width?
17x7 48mm offset. stock size tires 215/45/17. so 48mm is 3mm closer in than stock, will this negatively effect handling? i know the general consensus is that "wider is better"
1 - 8 of 8 Posts
