1 - 15 of 15 Posts
It would be a bit on the aggressive (assuming you're talking about the touring V2 wheels) side being 18x8.5 +33 and 18x8 +30. If you can find 4 fronts it would fit better. The wheels are quite heavy and your car will slow down a bit. MPG will be affected as well. I should slap on my 350z stock wheels on my Si and snap some pics. lol
Does nissan and Honda even have the same bolt patterns? I know Hondas don't fit on TC.
same lug patterns yes.
honda also has the same lug pattern as toyota. however, toyota uses 21mm lugnuts whereas honda uses 19mm. alos the hub sizes are different.you have to measure the hubs first. most likely, talking 90% sure the Z wheels wont fit an si
1 - 15 of 15 Posts
