1 - 20 of 36 Posts
I put Falken Ziex ZE-512s on my 2007 Si - does anyone know of a website that will calculate how far off my speedo/odo are off?
I put tires on at 32k and I only have 33.8k on it now so I am sure it is not too far off.
Any help would be great thanks!
If you put a 235 on the stock wheels 17 x 7 you are asking for trouble on turns. Your side wall will be super soft and I wouldn't doubt if you seperate the tire from the rim.
Tire shop (Discount Tire) said it would fit (but be widest I could fit) -no problems at all. I had a 4-wheel alignment done and the car feels better than new. The tires don't look too wide for the rim. Maybe I should drive it harder lol
That is the widest you can go, but discount tire doesn't know alot. 225 is usually the widest most go on a 7in rim. I am running 235/40/17 on a 17 x 8. Your tire size will mess up your speedo a bit. It is not really a 45 more like a 50 since the tire is wider.
Yeah if you're looking you can tell there is more sidewall but not if you arent looking for it. I had to get tires I was running on cords on all 4 Michelins and they offered this size cheaper than 215/45/17s. I only put about 100 miles a week on the car - sometimes less. I put the tires on in like February I think and only 1.8k miles since lol
Discussion Starter · #8 ·
So I am going 1.74mph faster than the speedo says at 60mph -not too bad.
I got the wider size because I saved $160 OTD which is a lot for a poor college kid lol
No, it's not bad. I ran 235/45 for about 20,000 miles. It actually rode a little bit better due to the increased diameter. Fills up the fender gap better too.
I originally planned on the 235's(45 17) when i got new tires last week but due to lack of supply i went with the 225's(45 17), and i'm glad i did. I'm still kind of mixed on how i like the 225's, theres a good bit more sidewall flex at higher speed that you can feel, but lower speed handling has def. improved. Btw, did you have to put spacers in to fit?
For reference, I'm running Acura TL-S wheels on my Si and I'm lowered on HFP suspension. This wheel is the same offset as the stock Si wheel but 1" wider. I had no rubbing at all with the 235/45 tire. I'm currently running 255/40 and I'm not rubbing but it took a little bit of work to make it happen.
Discussion Starter · #14 ·
Did you have to roll your fenders to run them?
- I thought in Honda Tuning Mag i saw some guys running 265 35 17(?) on the front and 234 45 17 (?) rears to Auto Cross them
I slightly rolled the rears myself with a rubber mallet and a heat gun. On the front, on big bumps, I was rubbing one of the clips that hold the fender liner in place. I had to remove the clip and tuck the liner under the tab. No rubbing now. I think I could run a 265 up front but I couldn't do it with an 8" rim. I'm under the recommended range for a 255 by 1/2" now.
Hey man, so how are the 235/45/17 working for you? I have some 2009 tsx rims which are 17x7.5, and lowered on HFP suspension. Am I gonna have any probs with a size lime that?
You should post up some pics of your car with these size tires as well.
what do u guys think about running 235/40/18 on stock suspension.
im currently running stock everything. im getting a great deal on the new rims and tires? input anyone?
I have put a set of 225/45/17 tires on my stock 07 Si rims and the fit is fine (got 50k out of the original 215/45/17 tires). However, since installing the new tires, I am experiencing light steering and a tendency for the car to wander at higher speeds and not tracking straight as it used to. I have tried having the wheels aligned twice and continue to experience the same. Installation of the new, taller tires almost seem to affect the wheel caster setting; skewing it several degrees negative. However, this car (like most front-wheel drive cars) does not have a caster adjustment.
For those of you who have actually installed 225/45/17s on your Si, have you experienced the same steering described above? If so, did you find an alignment solution that corrects the straight-tracking (light steering) sensation?
1 - 20 of 36 Posts
