1 - 20 of 29 Posts
I will be mounting my Enkei RPF1's 17x8 45 offset but can't decide on what will look/perform the best. I will be lowering the car soon, most likely 1.3-1.5 inches. I've searched for days but can't find a solid answer. TIA.
225/40/17 is my vote.
i have 18's though... but this is what im going with when i need my next setup soon as the Falkens wear out.
to give you a lil insight:
HFP springs
Skunk2 Pro-S shocks
215/40/18 Falken ZIEX ZE-912's
will be getting Yokohama S-Drives 225/40/18s
good luck w/ your decision.. hope others chime in w/ their ideas to help ya out. :thumb:
^ ...... hey would 235/40/17 rub at all on eibach sportlines on Stock s.i. rims ?
Should be fine
thanks , im not great with tire sized but if there was an issue what would the issue of the tire be ? too wide ? hitting my struts ? tires touching my fenders? too tall ? sorry have so many questions just GOT THAT ITCH to get some nice BFG DR`s or azenis rt-615
Back from the dead....
I've got hfp suspension on my fa5, if I swap my 215/45/17 tires to 215/40/17 wouldn't that lower my ride a bit more? Does this setup effect wheel gap at all? How would 40s effect handling wise too... Thanx guys
is there any height difference between 225/40/17 and 225/45/17?
if put 225/40/17 instead of 225/45/17, is the car going to sit lower? or just the whole sidewall gets shorter and the height remains same?
any comments. thanks.
1 - 20 of 29 Posts
