Passenger window all of a sudden will not roll down using both switches,fuse is good.has anyone ever had a motor die with no warning?
Sent from my SM-G973U1 using Tapatalk
First, smack the door hard with your hand while trying to roll it down. It will prolly be enough to free up the dead spot in the armature of the window motor. If it doesn't, then you'll need a test light to check for voltage at the motor. Note; if you free up the window motor by smacking the inside of the door as earlier described, it's not "fixed" and I recommend leaving the window up till you replace it.Passenger window all of a sudden will not roll down using both switches,fuse is good.has anyone ever had a motor die with no warning?
